How much for the AT truck and motor mounts? I have AT12 trucks but I am pretty sure they’ll fit.
Its $98.00 clamps, mounts and hardware plus shipping
Interested in a set for dual motor for MBS Matrix 1. PM sent
can you Shipping too Germany i m interested for 2x
3d printed wheel gears are on evolve website for 29.00 if that’s what your calling a flywheel
@rithblu Do you make mounts for this truck? It looks like the older Matrix pro MBS trucks, which I’m looking for
witch trucks are you referring to? Matrix 1st gen are ATS.
i thought the ATS where the non-spring trucks? I have the older matrix pros; theres a feature for a handbrake to attach to the newer matrixs don’t have.
Post 154 looks like the mounts I need; it has the profile for the handbrake. The ATS trucks looks like this: (no springs)
This one? Matrix 1
yes! 10 char
Cool ! I can have a set ready to ship tomorrow morning.
I didn’t see these on your website. How much for a pair of mounts and crossbars? Do you sell pulleys/belts as well?
No pulley/belts at this time .
The clamps for the mounts and cross bar I have to custom make, the cross bar is a little tricky because I don’t know how long to make it to your pacific setup. I would recommend that you get the mounts, pulley, belt first installed get everything where it need to be and aligned , so you can get better measurement for the cross bar.
Mounts for Dual Motor is $107.00 + shipping Cross Bar is 47.00 + shipping
I have 4 pairs ready to ship.
MATRIX II PRO Motor Mounts Clamps
Very nice. Any chance that you could add an idler on your mounts?
I was thinking something like this using the existing hole, but if you have something in mind.
That might be too high. I think it should be around this area
They do need to be closer to the pinion gear if your using that small of idler gear. If your going to use the existing hole I would recommend a 30mm idler pulley along with a 435-440mm belt for dual idlerz
I think 440mm belts are going to be ones needed so I done have to remove idler gears to remove the front two motor bolts. It’s a little tight with 435mm and I still have a little room to the rear for the motor
