Oh yes the shoulder bolt. I made press fit clamps for the Surf-Rodz Rkp’s needed longer axel bolts for it.
We make some small molds in house at work. We use it to square up steel completely flat. Also grind down core pins and Ejector pins.
Surf-Rodz RKP trucks clamps press fit. For ATC Motor Mounts. I like to thank @Makio13 for lending these trucks for me to prototype with.
So now i need some TKP trucks to work with.
So to all the eSk8 members i like to make a confession! I have an addiction i can’t stop buying parts .
The unity was an impulse buy, so its up for sale! I paid 315 shipped. Yes like i said addiction.
I think you need some help send me the parts and I will help you with your addiction . As for the tkp maybe ask @Skunk he may have a set he isn’t using currently on a build that he can lend.
Could someone describe what those 5 switch wires do? An analog on/off switch uses the same 5 wires or less than those?
Can anyone answer this for me? From a custom.
So I have not even really thought about gears yet, but we are planning on running both Trampa Gummies (urban) and 8" Pneumatics (offroad) The config is going to be 12s AWD with 4 6374s and two Flipsky 6.6 Dual Plus VESCs. I want great torque with decent top end 25-30mph minimum. Any idea if 72T would be ideal for this application? Thanks!
Oh and I weigh 230lbs
How much for those?
@Rithblu I don’t see why not. I’m running dual 6374s on 10s with 70T gears on 8" tires and it climbs hills without any trouble. Granted I’m about half your weight, but as long as you’re not expecting massive range it sounds like that set up should have plenty of torque.
It isn’t for me, im making some motor mounts for a customer for an AWD system he ask if a can make gear’s i told him yes 72t.
Not for sale my man, if i did shipping would kill the deal.
I run 72/16 on 8" with 149k & can go over 30mph
I’m currently running dual 170kv 6374’s 72/16 with 8" tires on 10s. Top speed 26mph and I havent found a hill that slows it down. 12s should give you 32-34mph with more torque than you need. 72/20 will also do about 41-42pmh. I have a few new sets of 72t aluminum pulleys for mbs 5 star pattern hubs if you’re interested.
The mounts are super solid! Just waiting on belts, but they are very nice!
Using something new, to make my mounts.
Can someone contact me about buying the Evolve mounts.
