I might be in touch with you, I currently don’t have enough money to fund the build but hopefully, I will soon.
Are the pulleys still made of Petg? How are they holding up?
Pulleys look nice Im in for a set.
I know the prices are listed somewhere, but I’m on the road.
Looking to switch to trampa infinity trucks. Currently have 15/70T with a belt length of 400 (Width 15cm). If possible, I would like to continue using my belts and motor pulley.
What does a complete dual motor mount cost, excluding motor pulley? Do you have a 70T alu pulley for trampa 8" AT wheels & what does it cost?
Thx
I have aluminum pulleys in size 72t and 60t If your motor mounts have a large adjustment range, you do not have to change the belts.
what belt width is your ‘‘stock’’ trampa AT motor mount compatible with when using 15/72?
For mountainboard - 20mm for Urban Carver - 15mm.
What are your motor mounts?
still have some of these sets?
Will these fit the mbs matrix trucks? The ones originally on the Comp 95?
Yes. What you need.
I have motor mounts for MBS Matrix and Matrix II You have 2 options to choose:
Type 1 with a cage, made of stainless steel, clamp rings made of aluminum.
Type 2 without a cage. The side plates are made of aluminum. One adjustable crossbar is made of stainless steel.
What’s the damage for option 2 ? Looks so freaking awesome!
It’s a standard ATB SPRING TRUCKS
For this truck there are the same motor mounts as for MBS, i.e. type 1 and type 2
Prices motor mounts type 1 i and type 2 are the same, - 100 Euro
The price does not include the valuation of pulleys and belts
A complete kit - 240 Euro
The complete kit consists of:
- Double motor mounts, [stainless steel and aluminum] - 1 pcs
- Pulley 72T HTD5M, 23 mm (belt 20 mm) - [Aluminum] -2 pcs
- Spacers and bolts for pulley [steel] - 10 or 12 psc
- Belt, width 20mm (for 15-72t) - 2 pcs
- motor pulley 15T HTD5M, 21mm wide (20mm belt), 8 or 10 mm hole - [aluminum] - 2 pcs
Hi Idea, great stuff, I sent you a private message .
