cool. Do you think you would take advantage of the holes on the ATS used for attaching the breaks? I was thinking of a clamp-on design that would hold the mount system in place. this is an 8mm threaded hole that might be useful in your design. BTW, keep in mind the standard wheels that come with the ATS.
I think it will be difficult to overcome cutting the barke attachment, which I have already done to attach the mount I have, made for spring trucks. I extended the bolts of the ring but I am not sure it will stay on very long with the vibrations. So I am interested to get a ring that fits.
@Oogappel, @jazzcool, @Rampano, @jga I designed new side metal sheets and fixing rings for MBS Matrix and MBS ATS The prototype is made of plastic but motor mounts will later be made of stainless steel and aluminum.
On photo from left to right: ring for MBS Matrix (older version), ring for MBS ATS, ring for MBS Matrix II and ring for Trampa ATB Spring
Looking good!
Perfect! Can I just get two rings for the ATS 12? I will use the plates I already have for now. Thanks
Oh! You have changed the holes so that people have to buy the new plates with the rings? You must be working for Apple…
No. You are the only person who wants to buy other rings.
I do not like Apple, I prefer LG I had to change the hole spacing because the hanger has a different shape.
Hi there @Idea , I’m completely new to this hobby and I have just bought a Trampa MTB with vertigo trucks and HYPA wheels. How much is a full set for dual drive and shipping to denmark?
Edit: I’d like these versions of everything:
I have 2x 6354 motors with a 8mm motor shaft and a set of VESC’s that this mount should fit! Thanks
Hi @Idea I am looking at purchasing the following and wondering what the setup would cost with shipping to the US. I’m thinking I need a 70 tooth pulley with 15 mm belt. Here is what I’m looking at purchasing:
MBS Matrix Pro Truck MBS FiveStar Hub
Thanks
What pulleys for HYPA? 62t or 70t
I sent a private message
I’d prefer 70t, thanks
Great work! How much for 2 rings, 2 mounts, and cross-braces for the ATS?
FWIW, I’m using a 20T/72T with 9mm 410mm/82T belt and 63mm motor. That should be a 78mm center-to-center distance.
I need a full dual motor mount, spacers, belts and pulleys for Infinity Trucks + Hypa wheels.
These look great! do you offer single drive sets? Also how do I order one ?
