Nowind
August 22, 2017, 11:27pm
101
Ah Dude that sounds like a smart aleck
With chains its sprokets
With Belts its Pulleys
With spurs its spurs
too lazy sometimes, normally people understand the meaningā¦
More expensive is :
Adapter plates are 60ā¬ without VAT
upgrade from standart 8mm motorSPUR :
to 10mm 19ā¬ more
to 12mm 19ā¬ more
upgrade with Keyways 30ā¬ more
Regards
nw-esk8
August 22, 2017, 11:54pm
102
Perfect, thanks-- Not a smart aleckā¦ just a noob ;). Iāve been doing my homework/research, but this would be my first DIY board, so Iām trying to be extra precise and not make any assumptions.
Nowind
103
Haha yeah all goodā¦ just kiddingā¦
Nate
August 23, 2017, 3:45am
104
Thanks for the reply dude. This is going to be a weird question, how are you strapping your Lipos onto the deck?
kane
August 24, 2017, 3:55am
105
Hi Jenso, Are you likely to do a ālimited editionā soon? If so, what would this look like ā¦ Iām interested in getting the direct drives, but if your planning on a limited edition, I might hold off until then.
maki
August 24, 2017, 8:43am
106
He uses velcro to grip the batteries onto the deck.
mikenyc
August 26, 2017, 3:18pm
107
yeah, but it looks like the velcro is strapped with a special mount. @Nowind did you make that custom?
Nowind
August 26, 2017, 6:25pm
108
Not in the near futureā¦ one day for sure but actually i cant produce enough of the actually ones
Nope they are just velcroed with HK power velcroā¦
okay they are shrinked with thick industrial heatshrink first
Cheers
kane
August 27, 2017, 4:51am
109
Congratulations! That sounds like a good problem to have! =)
DavidC
August 27, 2017, 2:52pm
110
Do you find them on Hobbyking or on another shop? I couldnāt find ones of the appropriate sizeā¦
maki
September 8, 2017, 4:22pm
111
I have also been looking everywhere for it and had no luck so far.
Nowind
September 8, 2017, 4:31pm
112
Sorry for late replyā¦
Check this ones :
http://schrumpfschlauch24.de/index.php?cat=c240_152mm-48mm-152mm-48mm.html
I used same size but only 1:2 shrinkrateā¦ this will be even better IMO
Used it for : for example Zippy Compact 6S-6400mAh, 2 pcs next each other
Be aware ! The stuff is expensive
Nowind
September 8, 2017, 4:57pm
114
Forget to say :
you need alot of heatā¦ i used two heatgunsā¦
placed the Batterie after that on big blocks of aluminium to take out the heat fastā¦
@TarzanHBK
You asked me about the shrinktube tooā¦ see above for link to German Shopā¦
Cobber
September 9, 2017, 2:04am
115
Whoa ā¦Wall thickness after maximum shrinkage 2.8mmā¦
Do you offer the machined aluminum motor cage?
Nowind
September 15, 2017, 6:45am
117
Actually not in combination with the Direct Driveā¦
Chaindrive got it
geforce
September 15, 2017, 6:50am
118
what size gearing you run on that 12s setup to get 65 km
Does the price include the vertigo lower truck?
or are people having them shipped to you?
