very low, low, normal, etc…
What does this mean?
I changed from normal to very high and it increased my speed by 4km/h.
This explains it more in depth: http://www.rccaraction.com/blog/2013/07/05/how-to-get-the-most-out-of-your-brushless-motor/
short story: high timing is best for running your motor at its peak RPM most often low timing is for running low RPM most often.
you need to make a judgment on how you use your motor and set it accordingly.
It says it’s a relationship between motor sensors and motor phases ?,…does this apply to our Sensorless Motors ??
So have any of you guys measured heat (temperature) after a ride? Would that be an accurate indicator for this application? Do you apply the 160 degree rule here?
My motor never gets hot on very high timing. Warm to the touch.
