You can adjust the startup boost between 0.01 to 0.1 in steps of 0.01 - I would suggest starting lower than 0.05 and going up past it to see if you find a sweet spot.
That is the only way to fine tune the start torque based on your weight.
Changing the other motor parameters wont do much.
Also; The shuddering effect will be amplified with a diagonal drive system. Dual drive will have less studdering as the truck wonāt be able to see-saw
Also; There is a chance your sensors are not working, I would disable the sensor mode and see what happens.
I donāt think the startup boost actually does anything (at .01-.05 duty cycle) in my setup given that itās a sensorless value and my hybrid setup runs sensored until 2000erpm. I changed it from .01 to .05 to see if it would help, but it made 0 difference.
I know one of the chances i made helped the stutter a lot (though it still happens), but i havenāt tracked down which change it was. I do suspect that it was losing the motor max. Throttling to 60A per motor from dead stop may have caused it to freak out.
You could also try adjusting your phase advance. Setting it to 1.0 gives no phase advance and setting it to 0.0 gives 30 degrees (maximum) phase advance.
oh im sure it does something just probably not on sensored/hybrid I love my smooth start from dead stop too much to turn sensors off. I love in SF and it really helps with all the hills since itās hard to kick start upwards.
@chaka Could you explain what phase advance does exactly?
Ok I was able to replicate what you are experiencing. If you want to make the vesc foolproof you will need to lower the ramping, max current ramp step (at 1 khz) to .004 This has given me good results.
Remember the multiplier bug still exists so you will need to input .0004 to get the right setting. This will give the motor enough time to rotate and allow the processor to log position before applying heavy loading. You may lose a little snap on the throttle response. Since you are using the canbus and there is a processor lag the slave may still cog so you may want to split your ppm signal wire and run each VESC independent.
The best solution if you want raw performance is to ease the throttle and only go full throttle when you get at least a partial revolution.
Probably, this seems to be an issue with processor speed. you could also reduce the deadband from 15 to 10 in the ppm menu, be careful if your transmitter strays to far from 50% at dead stick. this should give the processor a little more time.
Did some more testing today and Iāve completely eliminated the issue. I noticed that the same kind of ācoggingā would happen when I broke very hard (just as how I started hard). I have a strong feeling that it has something to do with me running ācurrent modeā instead of ācurrent no reverse with brakeā. Here are the changes Iāve made since.
Motor Max: 45 (I wasnāt happy with my acceleration)
Battery Max: 35 (I know youāre not a fan of this but I promise Iāll keep an eye on my heat )
Motor Regen (min): 45
Sensorless eRPM: 6000
Max Current Ramp Gain: 0.02 (half of default)
PPM mode: Current no reverse with brake
Startup Boost: 0.01
Integrator Limit: 120 (re-ran detection a couple times and got 120 average)
BEMF Coupling: 850 (got about 860-870 after re-running detection)
Turned off traction control
Added ferrite ring on sensor wires
A separate issue I noticed was that my slave VESC, front motor, would sometimes fail to respond, or have a delayed response, which meant that I would suddenly get a boost to braking/accelerating a second or two after I throttle the respective direction. I had a feeling this may be due to the long sensor wires sitting right next to the motor phase wires. This is why I added a ferrite ring to the sensor wires closer to the slave VESC.
Recently i purchased an Enertion Dual Raptor and iām having the same problem as Jinra in the beginning. When i want to start riding the board from a dead stop or uphill, it stutters until i give more throttle of if i push it a bit up to speed first. It does the same when i give full throttle immediately. The rest is working perfectly. I followed the steps mentioned in the steps above but nothing workedā¦ Any advice from anyone?
Thanks!
I see. Well i tried to put into sensor mode but then the motors did not do anything anymore. They simply did not respond to the remote, while the vescās were receiving the signal.
