310mm belts running 14/36t are the length. If interested I have them for $10 each + $3 US shipping. 2 or more shipping is free.
Did you mean 320mm? Because thatās the shortest size I can find on your site.
Sorry, my site is not updated. I have them available, they are not shown on my site. If you are interested on 310mm x 15mm belts, my PayPal is [email protected].
Let me know if you have any questions.
I need them to be 12mm wide. Got anything like that?
Unfortunately I only have 15mm wide. I have 305mm in 12mm, it might work without the use of idlers.
Is 320mm still short enough to work with the idlers?
320mm is too long for 14/36t. If you change your motor pulley to 16t, 320mm belt would work. 16/36t setup also gives you higher speed. I have 16t motor pulley available. They are $15 a piece.
So, obviously the cheapest option is just buying the 305 mm belts, but Iām worried that even with the idlers removed itāll be too tight. Can you confirm that they work?
Best if you confirm on your end. Wrap a string around pulleys to measure.
Hi, I need set od two alsoā¦ Can you send it to czech republic (EU).
4 months in on this kit (TB 218mm Dual Idler - Size L) and still running strong! Averaging about 5 miles a day since I donāt get to ride every single day, Iāve easily put a few hundred miles on them so far. After I got the kinks out of the build I have only had to replace a few mount screws I stripped, then a couple inner tubes from his other kit (picked up some gnarly nails)
Very happy with his products
i would like to place an order for a dual 63xx motor setup. being new, is there a recommended list of items for the drive train build? i plan to purchase items from to fit your mounts. thanks in advance.
