Hey @Kug3lis what are the dimensions of that 6384 motor? Shaft length and motor length?
Another quick update straight from workshop. This is baseplate for mouting on the truck and motor mount.
Yes, it’s needed because the end’s of hangers go steeper.
Why not CNC your own hanger?
It’s possible, but how much material will be wasted… Imagine you start with a rectangular blank of aluminium and you take off 70% of it
true
10char
I’m so jealous of your Datron. Those are so nice! I love their vacuum table setup for parts like this.
This is looking awesome. I wish i had access to this kind of equipment
Very nice! Presumably cast aluminium is used for normal trucks and forged for precision, this is what makes them so expensive
How do you rate POM? I was interested in using it bolted to ABS, wondering if the shrink rate is the same ~1%
what is your gearing bro? 15t pinion 60t wheel
How are you getting access to this equipment? Acetal need an expensive 3D printer
If you look carefully you can see som milling traces on the POM parts too. So probably milled and not 3D printed
