So yesterday I received new parts for this build: FatBoy SS Drive with 1:5 and 1:4 configurations, and 2 x 80100 180kv motors.
I was doing hyper-lapse for assembling everything but the battery died and didn’t have yet time to edit as it was pretty long one but I have some pictures from assembling everything
Soldering those 5mm bullets on these leads there pain in the ass maximum soldering power plus several minutes holding on the wire to melt them together…
Preparation for assembling the drive train
So after removing the board from the “work table” I instantly felt that these motors are from another dimension… When I was assembling it had some hard resistance to sping the motor but it would that much that pulling board felt like I am towing a truck I didn’t expect it. The magnetic forces of these motors are in another dimension…
TIP FOR MYSELF: Implement board pulling feature in ESC To assist pulling with the same RPM from motors
Went out for outside and boy this gear drive is silent compared to inner gear
This motors transformed this board to dark side… They are massive… At first I thought I got wrong kv rating as it felt slow until I saw the speed reading that I am almost top speed but it didn’t felt like it at all.
It has nice torque but feels like it need bit more voltage and current to feel satisfied it feels like they are still starving… Running 80A motor and 80A battery… Motor constantly reaches motor amps limits and I have seen a dozen time I reached 80A on battery… So far heatsink of FocBox manages to keep up with cooling
I thought that bigger motors will heat up less but that’s not true as they are eating more current so based on IR it releases much more heat but I think the sizes make it dissipate that heat much quicker…
The battery side its bit sad right now as power consumption increased to around 20Wh/km per motor I am getting only 20km range with 12s 18Ah setup. But thank god still no sagging problems
5mm bullets with 12awg wire holds up without issue, no heating up detected.
The ride to work felt pretty nice, definitely lost some speed downgrading from 200kv to 180kv But I still have 1:4 setup but I don’t think I will switch anytime soon
If it doesn’t going to rain this evening, I will go to Hyde Park to do some filming and try some offroad as I haven’t yet unleashed its power
@tabbytabb can’t wait to test out ARC200 as these motors need POWAR and focbox’es bit struggling with them
