My build is 12s 12ah 50c max discharge - 2 x 6s lipo - dual maytech 6374s sealed with focbox unity - and wondered if this is going to be suitable? Rated higher than I need but price difference is negligible so may as well over-spec.
Any disadvantages or is this the ideal solution for charging and battery protection in my case?
Thanks @deucesdown for the additional information. Very useful! I added some bits to the original post. Will do more updates later when I have more time.
I’ll definitely make the FW available. Note though that this won’t be an additional functionality to the DAVEga. It only has a single UART port so you can either hook it up to a VESC or to a Smart BMS, but not both. Also even if I somehow figured it out, there’s not enough flash memory for combining the two firmwares.
You could make an enclosure for dual DAVEga though. The next obvious evelution step then is the DAVEga Unity!
Personally your 1.3 solution looks great. If only we could hook this up to VESC and get the data through metr same as DieBieMS.
I believe the UNITY has spare serial ports accessible inside via headers, they are there for future modules like the BT module that’s included. I believe they were planning on releasing the spec for these modules.
Hooking charge only smart BMS directly to unity would be ideal
Option #1.2 (LLT Power Smart BMS + bluetooth module) looks like the most builder & budget friendly option. Has anyone else used this BMS with success? I’m curious to know how many builders are using this product.
Ah nevermind, the output is just safe/no-safe indicator. But, things learned: there’s probably an IC that does what we want, and this guy uses a MUX too. And, the boolean output is on a clock signal, so you can tell if it crashed/froze.
Clicking around on analog.com, found this video, didn’t watch yet, but the title is nice
Oh, and this (15s, cell voltages, error less than 2.2mV, SPI). And it has balancing? But the diagrams look more complicated. $19 for the chip at arrow. Looks tiny!
Oh hey this is looking interesing now. Demo board:
The Chargery BMS16 that @Chrisjarram has linked looks pretty cool for use as an external BMS. Unfortunately, I haven’t been able to find any reviews. Does anyone have one?
I want one! I guess it has 6s balance plug slots on side. ? I’ll be looking n likely ordering. Seems to have more features and bigger price than needed for off board balancing
Not my area of expertise, but I suppose it could have to do with the fact the LLT BMS is rated only 60A and that’s only if you get the aluminium housing (as @deucesdown pointed out here), which probably dissipates a lot of heat.
