What miscellaneous parts should I have/stock up on?
I live in the part of the world where most of the stuff I need for a build is either, not available here, or it’s available but with prices marked up by 5000%. Ordering stuff online is the way to go.
Now the problems with ordering items overseas are: shipping can be very expensive, and/or delivery takes a long time. That’s why I want to order everything in one go, consolidate shipping to save some money especially items from US source. And order extras for each item for stock purposes to save me some waiting time.
So aside from the major parts, what other miscellaneous parts should I stock up in. (wires - what gauges? screws, nuts, bolts, xt90, bullet connectors, glue, etc)
Are you building the battery yourself or…?
If so you need all of the above you already said plus shringtubes, fishpaper, charging port, screw inserts, velcro(?), double sided tape is always good to have, some sort of foam for dempening, rubber around enclosure, risers, bearings.
Somebody else got something that i forgot?
XT90 Antispark, Screws, shrink tube, XT60, Cable 6mm^2, 2mm^2 and 0.5mm^2, zipties, foamtape, maybe some hotglue, soldering iron, pb-tin, bullet connectors 4mm, JST plugs for sensored motors, charging port, gasket maker, and then those things for batterys if building yourself.
I wanted to know like, general information, how the determine what size bullet connectors to use. And yeah it makes sense based on amp rating as you say. I was thinking there was a standard of some sort but now I know it depends on you and your build. Thanks!
While ago 5.5mm was “standard” but most of the people have finally realised that those aren’t necessary. Quality 4mm is more than enough. I use those polymax’s. Can’t say how quality they are but works perfect.
And for wire 10 or 12 awg. I use 12 in my dual, but if u use longer wires and make single I would prefer 10awg.
