@rpasichnyk@hexakopter I am also have the same issue @NineLives is having.
I was able to load up the custom firmware.
Right now there are two issues I am encountering
Metr pro module flashes green and blue quickly. Iphone app says connected but no data or setting is being sent
Unity is having trouble configuring through USB with Metr installed on the comm port. Removing the module resolves this issue
Was it always blinking rapidly (green LED)? I donât know how that is possible, maybe you plugged it wrong? Or something is broken. Green blinking means that UART can not be established
It stopped working after I applied the new custom firmware.
I had to remove the module, apply new firmware, config unity then put the module back since unity doesnât seem to save setting when the module is installed.
Now it isnât working even when i reverted back to the old firmware.
