Thank you! Sorry for not probing enough!
@hexakopter does CAN ID refer to a specific ID number for each vesc, or is it simply 0 for the master and 1 for the slave vesc? Got my replacement antenna in the mail so everything is good again.
Quick question what does the antenna do and do you need it? May have been posted before but missed it
It increases the reception between your phone and Metr module. The bluetooth on the chip should be fine in most cases but if you have a carbon fiber deck or enclosure itâs a good idea to have so you donât get disconnections.
Reason I ask is because every time I have the Metr module on my board, I lose power to the motor on the slave vesc sometime during my next ride. Easy fix with the bldc tool but it happens every time! I say this sitting on a curb where one of my motors just stopped working.
When do you lose power? After you change modes? After you power cycle your board? This doesnât sound good. Can you send some logs?
@rpasichnyk Quick question: Can I also pay via bank transfer because my paypal account has been hacked
I have a 8 ply maple deck and a abs cement
After some more testing I discovered it usually happens after the board has been stationary for a while like at a stop light or while taking a short break to rest my feet. A simple restart of the board and itâs good again until the next time it happens. No startup mode has been applied nor does it happen when any changes are made in the app.
I will send logs soon.
Is it possible to connect this to a meepo board ESC?
@rpasichnyk what kind of shrink wrap are you using to cover the board? i had to resolder the header onto the pcb because it broke off (probably vibrations). needed to cut the shrink wrap off. currently have it taped up with some kapton
@Sharukh5996 Respond to your mail that you have send to [email protected].
@mikenyc Some 16mm clear heat shrink. Unfortunately I donât remember the actual source. You should be able to find some online when searching for â16mm clear heat shrinkâ. The whole JST 7pin 2.0mm header broke off? Never heard about something like that and it must have been more then just vibrations to brake it. Is it possible that a bigger force was pulling on the connector, like a loose battery or something like that? Would be great if you can send a picture of the broken module to [email protected] if you took one.
nah, didnât take a picture. it was inside the enclosure, not sure what could have tugged on it. it was pretty snug. perhaps the length of the cable was a bit much, i had to bend it awkwardly, thanks for letting me know about the shrink wrap, iâll check on amazon or ebay
Anyone else having issue with the TCP connection?
@Trdolan03 Is it working for you now? Do you had it working in the past and now it stopped working or do you have problems with setting it up?
@all I received a message that someone almost missed our Metr Pro two year anniversary and Black Friday 20% sale, because it is not mentioned in this main thread about the Pro module. Sorry about that. So here a reminder that we have a 20% discount at the moment that is running out on 25/11/2018 7PM UTC (Sunday, November 25, 2018 7:00 PM) so in slightly more than seven hours. You can find more details here.
If you havenât seen it yet, we also released a new Metr app version with Audio Announcements You can find more infos in the following thread.
@hexakopter it has worked in the past and stopped working. I tried yesterday and it wasnât working. Is there something you changed that I should try again?
@rpasichnyk it is working now. The second âTCP serverâ wasnât showing up yesterday on my phone as seen that it is today. The 10.0.0.24 wasnât showing up
Awesome! The first one is your cellular, and probably 65102 port is blocked by your internet provider or something. The second is your Wi-Fi.
