Thanks for reporting, I will have a look. Siri shortcuts are interesting, will look into that as well!
@taz The app shows relative elevation instead of absolute when using barometer. And I don’t reset it when starting a new ride. I will so it always starts at 0 in the next version. Thanks!
Worldwide means that it doesn’t matter if you live in Europe, the US, Australia, or anywhere else around the world, you pay the same for shipping. If you live on an island with special postal rules, contact [email protected] and we will check if it is possible to ship to you.
I may be alone in this request, but does anyone else here think the following would be a useful feature?
Metr app notifies (Vibration and/or pop-up) when battery has reached additional specified voltages.
I realize these notifications exist for low and cut-off voltages, but it would be nice to have one for charging as well. I don’t like to charge my batteries all the way to 4.2v, which means that I need to keep a constant eye on Metr or the meter on the board. Plus, I can be a forgetful person.
Might be wrong thead but anyhow this is an automatic brake if your remote disconnects “timeout” . Most people leave it off as it can be dangerous if set wrong. Needs road testing and adjustment.
I think its intention is to stop a runaway board. But if its set too high it could be real bad, imagine your riding along at high speed, your remote disconnects then the brakes come on hard then you fly like sack of potatoes into traffic. FUN!
i have the metr pro, it updates quiet fast so i have the battery level but without doing anything it jumps from 28 up to 39 is there a way to slow the updates so it jumps around less update interval in miscellaneous doesn’t seem to be doing anything
What do you mean with “without doing anything it jumps from 28 up to 39”? Do you mean that when you strain the battery while driving and then stop, the battery level goes up? Thats normal because the value is calculated from the battery voltage which goes down while you are pulling some amps.
i plugged the module in my esc and plugged a 4s battery in for test purpose to see if i could connect and if it al worked, it did but the battery level jumps around without me giving an input or anything
Strange. So I guess your battery voltage is also jumping around? You can change your displayed values and layout in the realtime data tab with long pressing on the screen and then arrange the items.
Totally forgot to mention that we updated the FAQ page and added information about Metr Pro connection, the four absolutely needed pins, external/internal antenna change etc. You can have a look here: metr
Let us know if you think there is anything else missing.
