Subbed! Good stuff mate. I can’t wait to see how this build progresses.
It will take bit a while, my drive train is likely will come only in July taking account all those 107mm people will be ordering
Damn I hate that falcon is all red
This similar should looke mine, but only Red&Gold
@ih8Darian you need our red case with mounting plate for you project
https://shop.3dservisas.eu/products/limited-edition-red-dual-focbox-case-with-cooling-fins-v2
I am continuing discussion here regarding my Balancer Modules:
@fedestanco I have like 20 left of them so not much I can spare
Idea is like this
Features:
- Cell Balancing
- Cell Voltages
- Group Voltage
- Group Current In/Out
- Group Temperatures
- Coulomb IN/OUT tracking
So these are like individual p group cell balancers? Or do they act as even more of an bms…?
It’s more like 12S1P balancer and coulomb counter 15 times
Hi Kug3lis, I’ve been following your posts and I’d like to purchase the 107 drive train kit when it’s available. I have the money ready to go, Is there a waiting list I can jump on?
There will be a pre-order group buy after we get test results from testers ir everything is alright it should roll out at around mid-end of June
Awesome, I’ll patiently and tentatively follow the progress. Ty
Hehe there should be still tomorrow if some kind of storm doesn’t appear today
Will be posting several updates regarding this project Just finished PCB design for Balance board looks pretty nice
Spent some time on CAD to design the front “X” handle for easy caring as 10" calibers will not have same handle ability as trampa trucks Also I feel like I need something in between bolts like logo or maybe text don’t know yet…
Sweeeet, wondering, because I’m not removing my x things. Would a small riser that bends upwards a little from underneath the front of the evo deck after following the front wedge be possible?
I guess yeah but the bend would be done somehow mechanically because machine at angle is time consuming…
If only that screen could display the current speed or battery % Is getting such info possible from slave focbox as all ports of the master are taken?
I am planning to connect it to my main mcu to which both vesc (later on my esc), bms and everything connects
I am thinking of using this module:
https://www.4dsystems.com.au/downloads/microOLED/uOLED-128-G2/Docs/uOLED-128-G2-Datasheet-REV1.pdf
Regarding simple vesc hookup I think you would need arduino to split between vesc and bluetooth module or you can use uart on slave but this is custom controller so you would need to make another processor to connect to vesc and show what you want
