Yo the red dual focbox case looks so freaking HOT this will be freaking dope on top of evo
That confounded me a bit too without a protractor, then I realised they had it stamped into the circle marking of the baseplate
Honestly I like the complete red hub with the gold hardware… looks awesome
Look at the bottom of the truck
Mine says 50
yeah i know, that was the entire reason for my post
“I realised they had it stamped into the circle marking of the baseplate”
Me too … This build is gonna be sweet. I’ve thought about moving my focboxes out into a case so it’s like a spoiler on the back of the Evo hahaha… Riced to the max. But hey cooling fins…
Lol sorry should have the last part
Hey, maybe you want custom blue case?
Mine doesnt had it I had to go check personally on angle
I am thinking if it wouldn’t be too much of red
Maybe…but look at Iron Man himself… It is pretty much a red suite with some gold pops.
I am sure it will be fucking awesome no matter what you go with; I really can’t wait to see this one complete!
P.S. I am going away from LiPo as 8 x 6S would cost a fortune and will go for PF 12S15P something like that, will be building individual balancer for each P group and somehow will need to make a case
It will be like 3 rows of 5 groups consisting of 6 cells in two floors
Will be getting 3kW power supply with adjustable CC/CV and charging it with it But biggest cons of letting go lipo is charging rate I could charge lipos like 5C without problem 18650 max 1C
But I guess with that kind of range it shouldn’t be a problem.
Also I will try to fit 2 x 8072S at 165kv first maybe if I grow titanium balls and then I will switch to 250kv
12s15p, thats serious!! Might be the next biggest battery we have seen here
Mysterious
Are those mudguards for kegels?
1.8 kWh? That’s crazy on a street board.
If I am going to use 18650 and can’t quick charge like my lipos in less than 30 mins then I need some range
Charge time on 15p tho?
A BMS that can handle a high charge current(and a supply obv) is a must on that beast. What do you plan on using? High Power hobby charger or integrated?
I am going to use CC/CV 3kW power supply to charge it, wll use our Sparky switch modified to work on both charging switching and load switching. Also separate P group balancing (Balancer per 12S1P) interconnects to main BMS mcu via I2C Wanted to use some advance level Balancer IC with isolation and etc but their are not available for consumers and requires NDA
P.S. I am going to charger somewhere in 1C range
