Parts List: https://docs.google.com/spreadsheets/d/1mCr3IZigZyqd6hAywdA-ly7xonvWtfPw7dnJ8BKHA3g/edit?usp=sharing
Almost a year ago I decided to try my hand at esk8ing and bought a Wowgo to test the waters. After many accidents, saves, fun times, and yes; expensive hospital bills, I can say that it’s one of the most rewarding hobbies I got into. Now after 800 or so miles it’s time to ditch these hubs and invest in something with a bit more guts. Now that I’ve finally started buying parts I figure it’s time to make a build log!
-Deck: Zenit Marble 38 When looking for a deck I knew I wanted one with a kicktail and it had to be stiff since it needed to stay stable and predictable at high speeds. I knew I’d be running large wheels as well and the large flared wheel wells let me do just that. It also has a sweet marbled design layered in the fiberglass to boot! I originally used this for my Wowgo since the v1 deck was so bad, and threw a Psychotiller enclosure over everything to avoid the split enclosure look. Status: Delivered
-Trucks: Taco 180’s Just some random cast trucks I pulled from a pintail I never rode to replace the stock Wowgo ones. They seem good enough and I swapped the bushings for Riptide Canon WFB 88a so they’re stable in the mid 20’s but good for carving at any speed. I will switch them out but for now I don’t see an issue. Status: Delivered:
-Motors: Carvon Speeddrive R V4 You know when I said a “bit” more guts? well… anyways, I had been saving up for a set of these but never knew when or if I would get a chance to purchase them, so when @kylem21 posted he was selling his pair I knew I had to jump on it. (thanks!) Status: Delivered
-Battery: 12s4p TorqueBoards 12s2p. I was originally looking at Psychotiller packs but the value of the included enclosure and battery meter swayed me over. Samsung 30q cells, which are a step up from the Samsung 22p’s in my old wowgo 12s2p battery. That one was giving me issues with power loss when drawing a lot of amps, full throttle from a stop for instance. Status: Ordered
-Enclosure: TB 12s Enclosure I had a sweet Psychotiller one but didn’t use washers under my nuts so they tore through the plastic. This one comes free with the battery so I figure I’ll check it out.
-VESC: Focbox x2 What’s to say? I’ll be running in FOC since I loved the slence of the hubs compared to my friends belt driven board and I’m fine not pushing my limits until I get lots of pads. I don’t know a whole lot about these so I will be reading a lot until they arrive and I guess go from there. Status: Delivered
-Controller: GT2b I’m going to print the MadMonkey case for it. Status: Delivered
-Wheels: ABEC 11 97mm Flywheels Found a set on ebay. Man are these expensive and hard to find. Status: Delivered
-Other bits
- 6x bullet connectors
- heatshrink, 10awg wire, xt60 connectors
- xt60 parallel splitter M to 2F
- Loop key circut terminated in xt60
