Since I am currently trying to build a stealthy build I thought about charging port solutions.
The standard 5.5mm plugs seem pretty low-tech and I thought about how amazing the magnetic Apple charger port actually is.
Has anybody ever thought about using this type of plug for the DIY build? Seems like a great idea with a self-locking mechanism and dual power rails.
It should easily be doable with a magsafe 1 plug and a magsafe 1 to 2 converter that acts as the female end on the board. Solder the cables to the male magsafe 2 side and you should be done.
And you could use the two outside pins for negative and the inside 3 for positive, or the other way around. That way you could plug it in any way and not have to care about polarity.
Hm - I wonder if the voltage for a 10S system will destroy that small PCB and chip.
Also I don’t know if the chip is wired in parallel so that the energy transfer can still take place even when the chip is blown. LEDs and stuff we don’t need anyway - just a direct connection from one cable to the other is already enough.
To test however I ordered a used DC board from an old macbook. Will let you know how it turns out. Cable part will be from a broken charger I have sitting in a drawer.
