I can’t really say, I only use vesc, and sometime it goes a bit up than the limite… but I never notice something like that (if I remember well)
maybe copy your post on the unity thread to get some enertion fedback
yeh on the Unity thread they are very busy with all the people mad for the cut out problems with hight Kv motors. So if I post something like that it will just pass. I will wait low tide and post it.
Got those babies!
I’m running them with haggy wheels and even tho they’re the 70kv version, they’re pretty darn good!
I don’t have metrics… yet, due to what I think is a metr incompatibility with iOS 13.
Pretty satisfied customer
What motor and batt max did you end up using? I’m still accumulating parts for the MAD DD build.
man you where so fast! I ma the last one to try them with haggy that’s not right ahahhaah Amazing deck btw.
I still have the 60Kv version to try it out. Which battery do you have? @riverside.rider we are getting there finally!
Do you have unity or other vesc? BEcause unity has the new app from @sofu and maybe you can be beta tester in case.
I’m on 11s3p 30Q. I’m 30a battery max, -10A battery min, 60/-60 the motors. I’m using two focboxes.
Right now it’s almost on par (torque wise) with the eLofty 56kv.
Pretty surprise of that since it’s a way higher Kv. Sometime I am wondering if that plus minus 20bKv does something in reality. Anyway if you have focbox you could get a cheap Bluetooth module for a ips app. Wierd that metr has a problem with IOS. I thought it is fully compatible.
On a single motor build I swapped 190kv to 170kv, very noticeable difference! Both were SK3 6374.
ok I will tell it when I try the 60Kv need to understand.
Definitely they’re not suited for hills lol They probably were 200F after a long hill.
How were the eLofty’s on the hills?
With the Haggy they would die only for very very steep hills.
To be honest still have to find a motor that doesn’t get hot on hills or when you push it hard. Thanks for the metr data
Oh yeah no complaints! Strange that I got cut off, we don’t have temp motor.
Other than that, which was expected… man impressed with the build quality, they’re silent and darn light. Love them!
cut off I guess then is BMS or VESC based. I see the temp when pretty high in your metr data. I wouldn’t advice to put them under too much stress on long long hills and with Haggy that ask more power for sure. With urethane they take hills as a champ but after several one I ride a bit more chilly to get them rest a bit. At least that what I do and I have 1000km on mine.
Yup it might be the VESC. IIIRC the cutoff is 100F
BTW I’m impressed that they handle the haggy at all, again, you’ve done a great job sir!
Thanks, well to be fair the motor I simply tried all the hubs out there and founda good quality/price. For the DD conversion, then thanks that took a bit of effort to make it happen
How were the temps though? Also curious about the TKP setup on a DD!
