@yummyblobs
@Titoxd10001
@saul
would anyone in the LA area be interested in going in on a spot welder? the sunkko 788h can be had for like $150 now.
i would just get it outright but it would be sitting around unused about 99% of the time.
we could work out details on who, when, how.
I already have a sunkco 709A if youd like to use it you can. Im in Rancho Cucamonga.t
willpark16:
Can u do .15 on that
not sure what this means. wat?
Jinra
August 21, 2017, 6:25pm
6
.15mm thickness. I got one recently on ebay and it should be able to do .1-.2mm thickness
says it’s spec’d for 0.1 - 0.2mm
Jinra
August 21, 2017, 6:42pm
8
I think that’s essentially the same mine, but $20 more
I have a spot welder, any of you guys wanna just borrow it?
The 709A I have is good for .15.mm nickel
What settings (sorry if I’m ruining this thread) I’m in Irvine tho and ur welcome to use mine
Im no expert on using it but I use the 8 pulse setting and set current to the max of 8 as well.
Hmm alright I was close thanks
Jinra
August 22, 2017, 1:36am
16
What voltage do you use? I’m about to start using mine, but I’ve never spot welded before
I don’t think the voltage on my unit is adjustable. It only has variable current, # of pulses and welding pressure.
I got a tip for anyone using these spot welders. If using on 120volts, go easy on how fast you tack those welds to the cells. These have been known to have either a blown circuit board trace. or blow triac.
Glad to see forum members willing to share their spot welders. Will definitely take someone up on that offer when the time comes
