I’m not so sure about that, form the logs of my board the amount of time I stay at the peak discharge of my battery is really small, and I live in a hilly city (not SF level)
You can look at the study made by @bevilacqua to see what the average draw from a board is like
Will take a look, what is really needed is taking the cycle you developed and doing cycle tests with that for the most used batteries and adjust for different packs configuration, wished I had the resources to do that
FWIW evolve said they tested the 30q against the 35e and “35e performed better”. I dunno what this means, but they’re confident in their findings and actually offered to send me a 30q powerflex pack they built for testing to prove to me it’s not better… of course I said yes but they will send it after a few weeks when the launch excitement dies down
You don’t know that for sure.
It might be the same price for me and you but not necessarily for a big quantity purchase such as the one made by Evolve.
its odd because at the 10A dischage thest it becomes only a 2.4Ah cell, while the 30Q was tested to 2.9Ah (dampfakkus.de).
The IR is a lot higher (28 vs 18 mOhm) = more heat = more losses… especially at pulsed high discharge situations
They have to be cheaper @ bulk like @taz suggested
Would be cool to implement an E-skate testing cycle for single cells…, maybe based on my Driving-cycle coupled to a standardized rider/weight-current consumption.
Moochs and Lygtes findings defere from Dampfakkus.
There is a long thread on endless sphere 30Q vs. 35E, the e-bike guys prefer the 35E because the cells degrade slower than the 30Q under moderate loads. I would like to know what the peak amp draw limit of the GTR is.
Can see the amps by running on this screen.Can also know the approximate voltage for which the remaining 1% is defined.
According to my expectation, it is about 30A at maximum in GTR mode.
My wild guess is, since the prismatic cells degraded so fast, that they are aiming for a longer cycle life with the 35E. In all other aspects the 30Q outperform the 35E in a 10S4P battery.
97 mm wheel, 6 inch AT tire. It seems to be optimized in combination with these. GTR peak amplifier may be lower than older GT series.
As a result, it may be balanced with 35E cells.The KV and gear ratio of the motor may also be different from the old GT series.
