Greetings from Finland! I have taken only couple first steps with my built but wanted to share these with you! The LLRH comes from Light Long Range Hybrid which state my goals. It’s my first built so let’s hope that I will meet these goals.
Parts for my board are:
Ram Lokz complete
74mm OJ wheels
APS 6355 190kv sensored motor
Custom mount
9mm XL belt + wheels
2x Multistar 6s 8000mAh
Wireless WiiMote
I have everything else but VESC. It will hopefully arrive next week.
I started with the mount. It’s milled 10mm aluminium welded to truck. Btw it was my first aluminium TIG weld!
It’s some old manual machine at work, haven’t even bothered to check brand. Pulley is bolted thru the wheel and has 3d printed spacers to align with the wheel.
Been following for while and felt so bad when I saw that pic. Sorry dude. Indeed some extra bottom carbon layers or just some strips on the sides could do the trick.
Gonna glue it or start over? If you can peel off the carbon, it might still be gluable.
I’ll throw away that deck.I will assemble those parts temporarily to my cruiser, but not sure what kind of deck to get next and how much I should modify it.
