Thanks! 10chr
Unity set up.
I have gone with the stock settings when setting the unity up, given my board set up is there a setting i can safely change for a bit more poke from start and at low speed?? Currently it kinda hits a power band at circa 15mph!
Check out FastLED, it’s library will blow your mind clean off desert eagle style :https://www.reddit.com/r/psytrance/comments/8l1vt8/built_something_fun_to_bring_to_festivals/ Totally r/whoadude type of stuff, but is takes arduino as logic controller
You can increase motor amps max, up to maybe 120a. But that gearing with that kv with that size wheel is gonna be high speed low torque.
Beauutiful build, thanks for posting. You’re not giving yourself much room for #2!
Cool thanks, ill try that, if it doesnt improve it much ill change the motor sproket to a 13t, i was kinda trying not to coz its on there!
It’s awesome! Like really really awesome! Good job!
Do you have any pictures of where and how the light is mounted?
Excuse the mess! Its just one strip along the centre. The apa102 is super bright!
I have been playing with tinkercad (thanks for the tip @olestra )
I have this xlite 100 which i quite like
It nearly fits in the socket but the 3d printed cable riser is a slight obstruction
So i wanted to make my own riser to house the light but retain the cable guides
Printed at 100% infill for strength in pla for now untill i can get some petg for the working version
Happy with that so far, and a fun little mini project/learning curve
First local group ride tonight, here is a quick vid, i love the sound of those gears!
The rest of the group were behind some ways
So pretty much wrapping this up, the board runs great, black filament arrived and the riser was printed and fitted, no drama there. Also the TB110 wheels arrived, these were part of my original plan for this board, and i love em with this drive train.
