So its about ready, my first build, coming from an exway x1 i hope to be scared! The exways let down is the silly short range, i needed more range and going on local grouprides enforced this more.
So i started reading here and what a resource! this build is 99% a forum harvest, so thank you to all you folks.
Heres the spec…
@Hummie deck
@bigben double stack enclosure
@3DServisas fatboy mini urethane drive 1:2.6 and 1:2.8 options, 2x fatboy 230 hangers, kegal, haggy, abec drive options
Riptide bushings
Caliber split baseplates 44 and 50 deg
12s 6p 30q pack
@hyperIon1 maytech 6374 190kv via @pjotr47
Bestech d140 charge only via @bigben
Glass frit grip.
@riverside.rider haggy nummies
@torqueboards tb110 (when they arrive)
Unity (on the way)
@akhlut s awsome x things
This thing is great, one of the fewer hummie options with geardrive and even front mounted! How is the clearance in the back? Any room for bigger motors?
I’ve bench blown (once actually explosive) a few of the 4.12 and a focbox or two, the common problems seem to be eliminated, going from the build pics and detail above I don’t see an expensive failure in your future
This is how sturdy they are apparently
https://forum./t/my-time-with-enertions-unity-beta-1-foc-motor-controller/17?u=magharees
