yea 2p with basen will be a cake walk youll be fine.
we use bms for many reasons where do i begin.
easy charging, plug and forget
cheaper than a 10s lipo charger (trust me i have one)
quicker charging
professionalism
longer life for cells
over charge protection, over discharge protection
soft switches
thats basically it.
I honestly donât see the point of not using a BMS. You can get one for arounf $35 that will be good enough. At 10S you should not draw more than 60A ever.
easy turn off and on
anti spark to save connectors life
professionalism
solid state skateboards ( dont have to open the enclosure everytime to turn on and off)
Bmsâs, soft switches, all these things are luxuryâs not needed if you dont want to use them.
I use them though because i like to spend money and i love the features they offer
No it wonât balance ⌠But will allow you to choose an end voltage ⌠For example ⌠Is you have a 12s set up with out a bms ⌠You really wouldnât want to charge it to 50.4v⌠You would want to end it @ 50v âŚ
If you have no bmsâŚyou need to give yourself a bigger range to play with so you donât over discharge and donât over charge ⌠Plus will extend the amount of cycles you can charge
