The charge port is connected directly to the pack POS & NEG. Im measuring the balance leads individually.
Well thatās just cool as hell :). Have you done a write up on it?
Nice, there no is load them, I guess itās the cells recovering after current in or out
Really neat brotha. Mind spilling how you did the software?
@mmaner Nah -On my board I have a normal charge socket that connects directly to battery +ve and -ve .
No BMS in board enclosure at all ( one less thing to break down and I donāt need BMS to fail braking down-hill)
My battery has all 11 balance leads bought out to a weatherproof socket ( using 0.75 sq. mm high temp silicon wire) for the external BMS. I put 5A wire fuses in these leads to protect battery ( and prevent a fire) should there be a fault.
So I can charge without BMS directly into normal charge socket on the board ( which I do 99% of the time)
or I can plug in BMS box to monitor only cell voltages during charging through board charging socket
or I can balance charge through BMS box using the 11 balance wires ( which I havenāt done for a month or so.
Ultimate flexibility !
BMS from AliExpress - with PC uart connection
Even comes with a Bluetooth module for android phone cell voltage monitoring and configuration capacity
Personally I would include a BMS in all my packs that I build, that way they can easily be charged just with a charging brick, however, I generally only use a low rated amp output current BMS, and bypass it for discharge, only using it to charge and balance the cellsā¦
I find this very effective if your ESC handles cutoff voltages such as a VESC derivative.
Thats quite cool bms and ācharge monitoringā box u have made. U should definetely make a sepereate post or tell more info about it.
Looks like u can also configure a few settings or the bluetooth is just for monitoring?
On a side note - to the guy who said his lipos drift in voltage - that is quite true, thats also why li ion tends to be more popular choice, i think, if really high current is not needed, li ion cylindrical cells drift a lot less or almost not at all, if they are from same batch and balanced properly in first place
