Pretty cool! What kind of pulley do you use and how do you mount it?
you will just need to check the clearance to the ground thoughā¦
Indeed, without a riser 5inch wheels probably will be too small and the enclosure will rub the ground in deep carves. A small riser should do the trick. Unikboards made some maybe they would work? Not sure about the angle in the riser, but maybe it would. http://www.electric-skateboard.builders/t/unikboards-group-buy-trampa-or-mbs-motor-mounts-angled-risers/19842
They are 35deg afaik, there are 3d printed ones on thingiverse which could be changed to 30deg. They would give the clearance you need, if not a riser as well, looking forward to seeing what peops do with this
oācouse metal would be better, maybe something to fill out the product line a bit
Possibly design some bolt on pulley to mount it. Will have to do some designing when I confirm the build
Since the board mounting holes are already angled, wouldnāt a flat riser extend out the trucks raising the ride height?
No the adapter changes the angle to skate, then you riser out the truck as necessary
Arenāt the LaCroix board already angled? Please enlighten me as I am very much into these eskate things
I think he means the Unik adapter that is used to transform a standard deck to work with trampa trucks
Oh. Ok! Got it. Haha. Sorry. Brain wasnāt processing
Ahhhhhhhh, didnāt know that detail. So the unikboards riser might be misadapted, Iām not sure. Anyhow, the point is a small riser would be needed for 5inch tires and possibly for 6 inch tires as well depending on how aggressively you flex the board when carving and what type of terrain you ride (on a bumpy surface we would recommend a slightly higher ride height - the enclosure on 5 inch and 6 inch tires might rub the ground during a deep carve over some bump in the asphalt).
Thanks! Good to know!
In the photos and videos you showed. Is that 7 or 8"?
7 inch. All the pictures and videos show innova 7 inch tires.
Trampa use bent alloy plateā¦ not just cnc
I donāt think it would be hard to machine, just a lot of aluminum would go to waste as it would need a square block to machine it fromā¦ Plus I think itās not needed that much thickness as it would be aluminum and etc.
Maybe there is already similar form U form profile it would save a lot of work.
@Cobber yeah cold press aluminum.
I know it is stupid but that plasticy looking baseplate annoys me.
What kind of flexible cable / conductor do you use for the battery serial connexions between compartments? Is there room for 10 awg to pass between the board and the compartments separators with no risk of getting crushed over time?
