What type of grease is it?
It’s made from lanolin of the Great Bronx Yak.
Does this mean just pump more in, or do we disassemble, clean it out, and refill? Sort of like an oil change?
Ok so what zealous uses in its bearings have you thought about using something from Kyodo Yushi there grease is actually used in some high end bearings that I have @b264 testing out for a winter torture test. There is also Turmogrease L252 they my last a little longer use lithium soap as it’s base.
They’re a hot flaming load of garbage while simultaneously being a lot of fun. Just say goodbye to your Wh efficiency.
