I mean he bought their motors.
And he is changing all original bearings Changed original shaft Changed Sensor
He also mentioned he doesnât believe they covered the motor when cutting the shafts. Which is just kind of asking for trouble cutting metal next to a bunch of magnetsâŚ
A much-needed thread! How about for sealed motors, you reckon the Maytech ones are good? And for non sealed, how are tourque boards? (or any reccomendations?)
@Badgermilk sorry for jacking your tread (nice username lol)
I donât know about maytech or TB. I think they are good from reading but I cant say! - Thats why we need a topic
Although I have seen issues with the closed can Maytech
A new topic on Motors would be great. The above topic is on electronic speed controllers. I started this thread to get advice on speed controllers.it would be nice to know what speed controllers you all are using. What speed controllers have you used without any problems over an extended period of time? Any tips on how to increase the longevity of a speed controller would also be greatly appreciated. I have a dual 6374 motor setup with a 10s battery, anti spark switch, and chain drive. Everything works properly except the speed controllers. Without price being a concern, I need a reliable proven speed controller or 2 for my setup. Thanks
Well lets say the ESC advertises FOC and 12s
Just do BLDC and 10s and your already off to a good start.
FOCBOX Flipsky 6.6 ESCape VESC 6 Ollin board ESC
Theres plenty of good:
ESCS Decks Trucks Wheels BMS
All made by the community
Focbox This thread is unneeded. This info could have been found in seconds if you searched.
Yeah, Ive read the Focbox is the easiest, and safest route to go.
Understand that all my advice in general is not of my own but of all the collective information Iâve read on this forum. But from what I can see
operating the speed controller within its advertised limits not at
Heat sink the fucker , the cooler it runs the longer in should last in general lifetime wise
Ensuring that all the solder points are solid and nothing , like the capicitors, are Susceptible yo vibrations
ensuring your connectors are secure so thereâs no possibility of anything being shorted god knows how
heat sink the fucker
Wait, so should we Heatsink the fucker?
Instructions not clear enough, dick caught in motor
The search function is your friend. Buy from esk8 sellers Stay off Ebay/Amazon This info has been covered more then a few times. And this is coming from a esk8 noob. I havenât even finished my first build. Thereâs TONS of info on here about just about every esc/vesc option available.
true but these threads are good once in a while. Like a âstate of the communityâ type of thread with the subjects being Escâs. Now if someone searches for a similar thread without the next 2-6 months , theyâll either find this thread or can be directed here.
So it looks like focbox is the way to go. Should I run in BLDC mode to add to reliability and longevity? Increase in sound doesnât bother me at all, since I run chains.
which factory makes em?
The chains?
nope, i was asking Moon about a motor supplier
You get what you pay for.
Focbox in bldc, 10s, 40a bat max, 60a Motor max and as long as you donât disconnect the CAN while switched on or piss on them you shouldnât get any issues
Just out of curiosity, which vesc settings and voltage you was running on the both which broke after just some days?
Thumb rule here really is; stop cheaping out on components and you wont get shit onesâŚ
