Hi guys. I have the 10S4P battery pack from @Eboosted
I have not charged my battery for the whole winter. I first checked my cells today, and I was shocked
Here are my numbers:
41,5
37,3
33,1
29,0
24,8
20,7
16,5
12,4
08,2
4,1
I cant belive that my battery is fully charged when I left it the whole winter without charging.
Is this normal?
Are those lotto numbers? Confused.
What is the overall voltage?
Can you show the voltage of each p group?
haha, I messured the voltages with my multimeter, Minus plugged in to my Battery Minus and then I checked all the ports on the balance connector with the positive on my multimeter, overall voltage 41.5V
That would indicate a well balanced pack! And no, it’s not abnormal for there to be little voltage drop when stored, as there’s nothing drawing off the batteries. Word of advice; better to store the cells at about 50-60% full capacity if not used for long periods. Prolongs the life of the cells!
Hope that helps.
Yes exactly what @Lionpuncher said. Never store your batteries fully charged, store them at 3.7V that’s 37v on a 10s battery pack or 40% of its full capacity.
If you know you will not use the esk8 for the whole winter, unplugging the battery and the BMS plug is also a good advice.
Storing your Li-Ion batteries at 100% for long periods of time might cause p-groups to drift and will decrease its life a lot
