Yes because unfortunately I’m not able to build motors in my 2x2 apartment
No because Maytech is a brand and there’s no French word to translate a brand. UNiK Polaris is the name I’ve chosen to OEM some Maytech motors of my selection. That would be a more appropriate statement. For the 6355 motors, all credits go to Jason back in the years.
sorry for the late reply; I’m in a kitesurf trip in Sicilia !
Trucks are Trampa Infinite MTB with reverse hanger (to get a more roadster feeling). Yeah it’s exactly the same build but a clone. That’s the 001 for one of my customer (mine being 000/Proto !)
Nice build, can I ask what type of tape(white) is used across the cells? I’ve seen it used as a structural but it’s not kapton, love to know what it is to have some around instead of hot glue
edit: Probably 3M™ Glass Cloth Electrical Tape
Designed to operate in 600 volt dry applications requiring high mechanical strength and resistance to high temperatures
getting prepared for the Trampa wheels ! The VESC6 are still performing flawlessly. Just did 40km easily around Paris. The remaining 1200mAH where used to pull from zero speed a friend of mine that had no more power in his Evolve GT.
The rolling resistance of urethane wheels… can’t beat that, same board would probably drain batteries in half of that distance with pneumatics. That’s awesome my friend! Those flywheels look dope
Cool build. A couple of questions I am doing this same build…12s4p Urban/Street Carver
Wiring:
Battery packs 1&2, 3&4, 5&6, 7&8, 9&10, 11&12 – you have those connected serially. Do you just make an (2) 4p and then join them together and butterfly them open?
Between 10 & 11 for example you have 12 awg wire between the middle of inner two parallel cells of each pack?
Where do you place the balance lead from the BMS on each pack?
I apologize for my noob questions but I am tried looking around all the Kaly, whitepony and similar 12s4p build threads and didn’t get the full gist of the electronics.
EDIT: This diagram does help a lot but I am still curious where the balance leads go on each 4p.
Trampa Battery mount enclosure
Frank and other build threads have them cutting the enclosure in the middle and staggering with hole+side only slit, how come you didn’t do that.
Well I just broke the bank… ordered mine x 2 Cant wait. But really I need to figure out this wiring with BMS at some point… maybe I will just post a build thread for my carver and ask for help soon.
