Hi guys, the new project is coming up with new gearbox using inner gears to make it smallest possible direct drive gearbox It’s nor possible to make any smaller because then motor 63mm will start to touch the hanger. Maybe there will be some trying to make 3 gear system but it’s only on the mind right now
There will be no need to machine a hanger, every gear will be machined from scratch so it suppose to be cheaper than our normal gearbox, plus it will have only 4 parts
At the moment my own 6384 170kv but should be working with any 63mm motor Top speed should be around 50km/h. It’s more for Mtb boards so high speeds are not much better.
Yup, actually with 12 cells you will need 350kv motor to achieve that if you go with 90mm wheels.
With bigger wheels lets say 200mm you will achieve 50 km/h with 170kv.
He’s planning to build MTB so no problem there.
Be sure to check with Lee13 for selling, he told me he is in the process of getting it patented. (if that works, I have no idea of you can patent this)
Lee13? I can’t find user with name like this here. It’s just inner gear with mounting plate, I don’t think you will be able to patent something like this
