here’s the drawing
that inner hexagon is the hanger. the irregular hexagon provides the clearances you need. right now it’s setup for a 1/4" endmill - anything larger will need to alter the irregular hexagon to provide the required clearance.
here’s the drawing
I can post it to github if you want.
Yeah that will be helpful, I know someone else making a clamp but he is doing it a different way too
2D drawing doesnt make sense to me for some reason. The 3D looks fine
Files are uploaded!
Made it a little smaller so it fits the gear drive.
Think its fine. Made the mounting points closer together so I could make the overall footprint of the clamp smaller.
The difference
what is the hole size on the motor mount, and what is their radius?
The hole size?
Which hole
@akhlut Is it easier to machine polygons in comparison to circles? Is that why you made it like that in your version
Hell yeah.
no. i did a polygon because i have to hand drill the setscrew hole. having a flat surface helps.
Ohh makes complete sense
also, why carbon fiber? an all aluminum case would help dissipate heat.
Aluminum would be a v2 feature. In addition to a 1 piece case and plate
I have a contact that makes carbon fiber sheets and they cancelled the stuff I need for cheap. If I had the same opportunity for aluminum I would do it.
youre in the uk?
Yes I am
gotcha. id cut it but shipping is spendy
Yeah it is but my contact is in China so I am already wasting money on shipping lol
But usually add other things in the package to make it semi worthwhile
i hear that!
US to UK shipping won’t be that expensive, it fits in a large letter and probably weighs less.than 500grams. It would cost me like £8 or so for me to send you that
from here to there is alm0st 50 bucks
Oh shit lolz. Even with something like USPS?
