190 kV is too low for 6S with that gearing ratio. Your weighted top speed would only be around 13 mph (~21 km/hr)
this was my setups on lipo’s and a APS 12s 120A setup. I managed to get 30 km/hour on flats proven with multiple gps.
12S is not 6S.
Why would you recommend the same setup at half the voltage?
I used 6s lipo with a 12s APS ESC …
Cheers that might help a little
So far I’ve got a board 80mm orangutan wheels Set of caliber 2 trucks on order. Just trying to figure out the electronics side, I’ve got the 6s figure in my head from watching the diy builds on YouTube including the one by entertion. Getting to get the bits together slowly but trying not to mess up as don’t have the funds for a lot of error. Motor mount I’d planned on making. Undecided what to do on pulleys and esc
Very inquisitive what everyone else has set up, will be trawling through the forum checking out builds latest
There you go:
on the 6s if u have a little extra money go for a higher c rate i think u might go for 20c but 40 to 65 is a lot more fun i had 12/36 2x3s 5000 20c 190kv sk3 im 13st i got 6miles and 22.8mph i changed to 2x3s 5000 65c same out come but getting to 22mph was a lot more fun
im not sure but this might be good 3x Turnigy 5000mAh 2S 7.4V 60C Hardcase Pack still 6s im doing a 10s set up wth 5 in a few weeks there 25e each
if ive understood right the higher C rating is the amount of current the battery pack can deliver, so a 5000mAh pack with a 20C rating can deliver a maximum of 100A continiously (5000mha X 20C)
that correct? so a higher C rating would allow more amps and so more torque?
ya,and its only a little extra to upgrade,also i think i have a 6s xbeast 150amp esc here for sale
245kv sk3 on 6S works ok - a little cogging so a push needed but to be expected as I’m 90 kgs. 192kv sk3 on 10s was better.
look at this Turnigy nano-tech A-SPEC 6600mah 2S 65~130C Lipo Boat Pack there so cheap right now i just ordered 5
this is a great buy you will only need 3 if i was you build a 10s dont for get you will only get 6-7 miles from a 6s setup
what did u think of the 192kv on the 10s what was the take off like also what top speed did you get
It’s a really good combination. Top speed over 30. Great climber. Needs a kick if starting on an incline. Favourite set up so far.
In doing 5 2s 6600 and a 192kv what esc are u useing
If that was a question for me. I run 10S2P Lipo 8,000mAh with 192kv motor and VESC 4.10
is there a thread on here for system set ups, just thinking would be good for me a total beginner to help get a feel for parts
setup motor/s - battery/s - esc/s - motor mounts - pulleys/gears inc ratio/teeth - wheels - trucks - radio gear
