I have a dual 6355 10s3p with 16/36 gears and I top out at about 27mph with 90mm wheels I was thinking of getting 18t motor pullies to be closer to 30mph is that a good idea or will I loose too much toque?
lower your wheel gear to 34 and see what that does for you. OR even 33. I’d try that before increasing your motor pulley size.
Who sells 33 or 34t wheel pulleys for fkywheels?
I do. Feel free to browse the other tooth counts. I also have them for Kegels.
If you’re using a standard axle length hanger, you’ll need to remove 8mm of aluminum from the hanger to use these, and you’ll need an F608ZZ bearing. you can get those bearings for cheap on Amazon. Like $11 a ten pack.
I will have 32t available in my Black Friday sale
Oh nice! I have the 218 mm torque boards trucks
