ESCape…
VESC-based ESC. It’s called ESCape. The “V” is trademarked.
Wow did trampa trademark V™ now? From now on we have to use the TM mark ev™ery time we use the letter V™? He’s on a strike!
Does anyone know the dimensions of two of these side by side?
Nope; I sure don’t. But two B-Box side-by-side should be very, very similar and are 140 x 77 x 21mm
The 140mm is hard
The other two will need extra space for wires and connectors. Cheers
The group buy with the dual case has not yet happened correct?
It happen. Do you need it?
The ESCape and case group buy?
I saw Stewi say something about a big group buy so he can get the escs manufactured instead of soldering by hand.
http://www.electric-skateboard.builders/t/escape-group-buy-professional-pcb-assembly/49720 It;s all there. Singe and dual
damn looks like i missed it
Is there anywhere 3d file of single or dual aluminium enclosure?
Single is available somewhere in the beginning of this thread. Dual is not.
I will make a dual case for mine as soon as they arrive… can make one more if you need it. I think @LukePL designes one so if he still makes them it might be quicker to ask him.
Can anyone confirm what size bullet connectors these have on the phase wires?
Thank you! I want to put some more input capacitance and anclose them in housing. Thanks to @LukePL I found single vesc 3d file so I’ll manage to start from here.
Mine came without bullets.
