Open it on a computer and not on the phone
Just no, and i assume you donāt have what iām looking for, else you probably just would have linked it. So canāt really give you a thanks or a like for this useless postā¦
I have it, but it only lets me put images on here is the problem. Itās the forum doing that, which is probably why it was originally linked from a dropbox in the first place. I also used a computer to open it on though, too and not a phone.
I canāt really thank you for being rude when I suggested the best possible course of action for you. Next time I will ignore you.
There you have it:
I just imported dropbox file to google spreadsheets for you, donāt know if the contents are up to date etc.
I appreciate that. That saves me a lot of read time.
Really thank you @webst, now i can fill my shopping cart. And in the evening when i get closer to my pc i can do things there wich i really could not do on a phone.
Does anyone have extra ā06035C104JAT2Aā they can sell to me? My order got backordered and most vendors look out of stock.
Itās better to use 100V capacitors anyway
What iOS are you running?
Edit: Ah nvm you got it. Didnāt have to be a dick about It though.
this is the automotive equivalent and in stock: 06035C104J4T2A
Nice job. How are you going to mount it ?
just wonderingā¦do you sleep?! itās 4 am here, so 7am there.
Eventuallyā¦not sure when Iāll let you know if it happens
This is what Iām doing right nowā¦looking at sexy holes
damn addict
Iām just getting ready to leave the office, been here for like 20 hours
Waitā¦ You are putting ESCape on a plate to improve cooling and than you insulate the whole surface with foam? Am I missing something?
The surface that matters is the one facing the ESCapes, the foam is on the backside for vibration absorbing
it is not ideal, but in that case the plate will āstoreā the heat, it will take longer to cool itself down but will still relief the mosfets from the heat.
Itās a nice chunk of aluminum, and I donāt plan running anywhere near limits for long
in this for a Trampa?
Iām wondering about the dual focbox case I have, not sure if I wanna cut a hole in the enclosure to vent the heat out.
Nah itās the Zenith
