How to by pass FocBox Unity integrated Power switch
Hey guys,
I have a Torque Boards 12S4P battery (The TB battery has everything integrated) and dual 6355 motors and I need a way to by pass the integrated power switch in the FocBox Unity. Is there a way? Besides doing a push to start.
Thanks!
Unplug it and turn auto shutdown off in the software?
You have to short the pins on the unity so it is in always on mode. Then you can add your loop key. If you have nothing pluged in to the switch port of the unity it will always be off no matter what you do. You have to make a cable and short the pins.
f875eab383a1c81171c2faa6ce0cd8bd01fc2935_2_1332x1000
Make the jst cable on the right and plug that into the switch plug to connect the pins.
2m
Hey thanks! I don’t know how to make that! What do I need?
A jst 2 pin connector with wires, then solder the 2 wires together.
