how to I fix my vesc. When I was using my vesc and it just stop working and now all i get is a red light
gonna need more info than that bud
OK then when I plunged it up to the tool on the computer all the settings were set to 0 . so I rest them and its still not working
Go to console and type āfaultsā. You probably blew your DRV and will need to replace it.
what dose that mean
In BLDC-Tool go to the terminal tab and sent the command faults. It will tell you the error.
Please post a bit more detail and picture about your setupā¦ Also have you try to contact your vendor
And WHEN did you buy it ?
Fault : FAULT_CODE_DRV8302 Current : 0.2 Current filtered : 0.5 Voltage : 33.07 Duty : 0.00 RPM : 0.2 Tacho : 84 Cycles running : 0 TIM duty : 8 TIM val samp : 1050 TIM current samp : 3150 TIM top : 4200 Comm step : 5 Temperature : 32.39
I bought this for some dude and how do I send you my set up
ahhh nothing better than a DRV error code. Can you take a picture of your VESC?
From witch compagnie have you buy your VESC ? It sound like the problem every one got with the 2.18 first release firmwareā¦
sorry my internet stop working so what do I need to do
hello sorry for not replaying
Do you have any pictures of your VESC?
no but can get you some
