Does anyone have a sk3 6374 192 Kv motor hooked up to VESC and SPACE CELL? If so, what is your VESC settings specific for that motor? Also what is the approx range you’re getting? I just tested my second build with those components and my range was pretty bad. I only totaled about 5 miles before I stopped at 40% battery life, which is about 1.8 miles per 20% battery!!! Did I do something wrong? could it be my gearing? Thanks in advance
My current setup:
VESC with 10S space cell
single SK3 6374 192kv on 14T 50T
5 in.(127mm) pneumatic wheels
GT2B r/c system
My VESC settings:
Motor max: 80
Motor min (regen): -60
Batt max: 30
Batt min (regen): -12
Absolute max: 130
I’m gonna guess that its because of the very low gearing and the really big pneumatic tires.
I bet if you where running a street setup like 16/36 gears and 83-90mm wheels, your mileage would be better.
What you have there is an off road hill climbing machine. Thats gotta cost some mileage.
Do you have a watt meter so you can measure total Wh pulled from the battery during usage? That will allow you to see of you are getting everything out of your space cell
pneumatics while drain your battery way faster than normal skate wheels.
With urethane, you can easily coast, and you are restricted to pavement- all terrain wheels open up some more challenging environments, and take more power to start them up and keep them going.
it is simply that they (on average) have to pull more watts than street wheels!
Back when we sold the 5inch pneumatic wheels, I did a single motor range test with both the pneumatics and 83mm Enertion wheels on the same route (all street, some light hills), and had 70%+ left on the street setup when the pneumatics had under 40% at the same point.
If your belt is too tight it can cause excessive watt usage. Be sure you have a little slack in that belt. Rotate the wheel and check the belt through the whole rotation to be sure the belt does not get tight at any point. Don’t make the belt so loose that you end up skipping teeth constantly either.
thanks for the clarification. Maybe I’ll try swapping out the wheels with normal wheels and see if there is a difference.
Hm so then what type of batteries would support the high drain and can give a decent amount of range for pneumatic wheels?
also, I’m not sure if I want to deal with Enertion anymore due to the terrible wait and increasingly poor customer service. Last time I purchased a space cell, I waited for 3+ months…
i’m using Lipos. They are a good option if your wanting maximum power. And if you mount them in a easy access enclosure, you can bring extras in a backpack to go on long treks. I have a maximum 30 mile range with 3 packs.
Although, I doubt my legs would hold up for that distance.
I’m running 12s with dual motors and the power is amazing. You really have to brace yourself when you get on throttle.
yeah, I am going with Lipo as well for the pneumatics. I’ll most likely run it in 10S because I read somewhere that it’s not good for the VESC to be in 12S as it creates heating issues with the FETs and such. Plus, 10S on a sk3 192kv and 5in pneumatic wheels is fast enough haha
yea, sorry buddy. That is why I decided to make my own pack instead. But just need to figure out how to connect everything without blowing my apartment up lol
I’ll have to agree that running 12s is pushing everything to its limits.
10s is surely better for longevity.
I almost went with 10s but found 6s lipos cheaper and more readily available than 5s lipos.
So I went with 12s.
12s is ok with belt drive because with gear reduction
You draw less amps.
If your running any form of hub motors, then better to go 10s in my opinion.
