I can send you jacobs manual - it is all in there. Give me a couple minutes
I have updated it for 5 mins ago, but should I remove it or what? I just added (Received) beside it etc.
@Sander if you no longer have an outstanding obligation from @Alextech, please remove the dollar value from the spreadsheet and note in the comments that the order arrived.
Umm the 12S4P battery? Removed the Hub Motor and let the 12S4P stay.
Thanks! It says nothing about the volt so I guess 12S battery should be no problem?
Shouldnāt be. I am supposed to receive a board w/ 12s4p battery and those hubs.
voltage is never an issue (in the limits we typically use - it will be if you go ridiculously high with 100s of Volt) but only current matters for our motors.
Ahh, I have always thought with more volt the current is more because, 100V * 40A = 4000Watt.
But why do they use like 1800 Watt motor marketing?
in principle yes - but to get the same power you need less current Because 1800watts sounds better than 40A
Some people are fine with the factory urethane. If your light ride short distances at normal speeds in a city thatās below 100F.
But if your big heavy or you ride hard long distances in hot temps you need the shit I invented
Any updates?
Hereās an update for my situation:
I sent everything back to PayPal that was in the box, including the box taped up to get rid of the holes that were in it when delivered. Should be getting a refund in a few days
All, After some prodding/reminding @Alextech has called and emailed his business mentor (Iām ccād in the communications) and we are awaiting a response so that the three of us can discuss the outstanding issues and identify a solution. I will keep you posted.
@mccloed @sukurity @anorak234 @willpark16 @Wubbalubbadubdub @willpark16 @Sander @localredhead
Hey @treenutter, Iāve received my refund so you can take my name off the list. Thanks for helping.
