The benefit to this is that they don’t explode… It will still works even if a few of the rollers fail. But normally they just start to spin slowly and make noise before an actual failure.
The solution is a custom skate truck with integrated replaceable wheel hubs(NOT HUB MOTORS, HUBS)
I mean, it’s a bearing so it should be as precise are possible or that will effect the overall life(which is our goal anyway.)
Iv’e thought about using the wheel as the bearing seat, but a hub built into the truck would still allow you to use normal longboard wheels, and not have to replace some super expensive cored wheel every time. it wears out.
Then we can just bolt the wheels to the hub, e z p z.
EDIT: This would also solve this whole axle strength/thickness issue we have been having as well(with the carvons, and hub motors).
I talked to the company that I have been in contact with and they said they are looking at some SS 608 bearings. Where the ceramics that you had explode where they ceramic or were they Silicon Nitride?
White balls with white races (ceramic/ceramic) and black balls with silver races (ceramic/steel). I don’t recall the details but could find out if needed
I was talking to one of the engineers and they had said if it was full ceramic then they could see them exploding. And could even see the ceramic and steel dying because there are varying degrees of ceramic. She said these would be Silicon Nitride balls with steel racers. She also said that if someone ever breaks the silicon Nitride ball to send them a picture and they will send out a replacement. I’m asking abut the grease and the labyrinth seals. Stainless Steel bearings might be what you may be looking for so they don’t rust.
The 608’s do indeed have what are you referring to as a laby seal. What I was mentioning below was that the 608’s do not have the extra inner race groove for the seal to protrude into. So from a sealing stand point, these bearings do a darn good job.
Per what you were saying, blowing up a hybrid bearing (hybrid = steel races w/ ceramic balls), is a bit surprising to hear. This is obviously not impossible, but it would be interesting for us to hear about the circumstances in which this happened. In no way should this be common for any quality hybrid bearing.
Per the salt roads in the winter, this skater is going to have to accept some level of contamination as icy/salty roads melt and this liquid splashes against his wheels. The heavy contact seal (RH), is probably going to be a darn good option for sealing against this liquid for longer periods of time. The RH seal is much different from the standard RS seal (light contact) and is extremely different than the Z shield, which has a gap. Even if this skater would choose a SS option, these harsh conditions are bound to put more wear and tear on the bearings.
All of our greases are more than sufficient for the skateboard applications, even under these extreme conditions. Water has the ability to wash out any economical grease and most non-economical greases. There are options to partially overfill the bearings with grease to help prevent some of the issues this skater is seeing. You would have to know the specific customer order to overfill the grease under specific circumstances, this is not something you want to do as a standard. Both higher grease fill and RH seals (vs RS) will create more resistance after installation and somewhat continued vs. other options. If I were specifically this skater, I would set up my board/bearings for the winter vs. other seasons
