I highly recommend you get the 60C packs, not 20C. With 20c you will have less range because of increased voltage sag.
Found the 60C packs x5, how do you reckon I can increase the cap all while increasing voltage, and sag
Yeah sounds good. Thanks for the help!
I used the 2s 5000 60c because they offer high current capability while having a very compact footprint. If space is not an issue, you could use Zippy flight max 8000 30c I havenāt had time to do a full on range test with this setup yet but I have logged about 13 miles without using up a full charge.
Thanks for the help, great diagram. Two questions-
Does the charge port come with the BMS? Iāve never used anything like this.
Where did you get the E Switch?
Thanks for everything.
Oh and what are you using for an enclosure? Sorry for all the questions.
Charge port is not included The E-switch is built in on Bestech BMS Just add an automotive switch to control it Iām using psychotiler enclosures
Hey man,
I donāt know how to send a private message so iām just gonna ask my question here, okay?
I regularly see people with motors that can pull a max om 80A. Online once read that the max ampere output of a battery is Ah * C So for a lot of people iāve seen its 5 * 30 = 150A
What am i missing?
Thanks, Bram
I answered your question here:
I know this is an older post but there is such a wealth of info! Thanks for taking this project on and sharing it with us. I have (2) 5S 5000 mah Lipos in series and itās such a bitch to charge which I do seperstely for each lipo. I donāt really understand the logistics of a BMS but understand what it does generically. After more research to come would you mind if I DM you when I feel confident to start the project? Again, great work here!
Happy to help and answer any questions you might have. I have been using this setup for a while now and I am very happy with it. I am currently building a second board with the same setup on a different deck and different motor mounts.
Iād like to see how the motors change the ride with the same set up. Appreciate the help in advice sir
The KV specs of the motor or motors is dictated by the the Vesc and the voltage. You want to keep the Erpm at 60k or less. 60k/7pole pairs = 8571 RPM When calculating, use full charge voltage, not nominal voltage. Example: 10s = 42volts 8571 rpm / 42volts = 204 max motor KV
Iāve found that 10s and 190kv makes for a very dependable setup with a good balance of torque and speed.
Iāve never seen that calculation, I donāt know how. You just saved me a shit ton of trouble. Thanks mate.
@Namasaki > 60k/7pole pairs = 8571 RPM How do you know how many poles a motor has? Specifically I am curious if a TB 6355 260kv is to high of a KV to use on 10s3p. And if x2 TB 6355 260kv is too high KV to use n 10s3p.
The reason I am so confused is that my kids board has a x2 5055 280KV motors and 10s3p.
Thanks for the expertise
260kv with 10s is over the limit when using a Vesc. 7 pole pairs or 14 poles is common for the motors we use including TBās motors. (Although, Iām speaking of 60mm motors and I donāt know about 55mm motors.) You may be able overcome this limitation by setting the erpm limit in the bldc tool to 60k. And as long as your not going full out at full throttle, you may be ok. Is your kids board setup with Vescs? If yes, then maybe they arenāt riding fast enough to exceed the limit. @chaka may be able to address this question better seeing that he is the expert on this topic and all I know is what Iāve read in his posts.
Hey there! I canāt stop looking at this diagram and your pictures! I have (2) 5S 5000 mah Lipos. If I was to keep my balance leads for the same reason (testing) would you recommend I get a balance lead to connect from the Lipo balance and then take the individual wires (minus the ground) from both Lipos into the BMS? In my head this is starting to make sense but in practice I feel like their would be some fires in my case. Thanks in advance.
Got another one for ya if you donāt mind! What kind and where did you get the charging port? Man, this is becoming more and more fisable in my head. 2 months ago Iād never imagine I could even solder let alone understand your post! Thanks again
The switch is useless but the charge port works fine. This charge port is the small version and fits the cheaper 42v chargers that are sold on eBay http://www.ebay.com/itm/222029867724?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I used these extensions to connect the balance wires to the bms: Theyāre really nice because I can quickly disconnect each battery pack from the BMS balance circuit for individual testing, charging or replacement if necessary, although I hard soldered each packs main wires for minimum resistance.
