Tb218 Tuck has a short wheel base, so he adds pads.
Motor mount spacing 173mm
6384 motors can be used.
The motor will use APS 6384S Sensored Outrunner pushless motor 170KV 4000W × 2.
Vesc will use ezrun max6 rc vesc.
All bolt assemblies use nylon nuts.
Gear ratio 1:2
wheel full 32t
motor full 16t
on the Evolve pictured above, he’s implemented the extension bracket, increasing the wheelbase LDP-style about an inch, and it’s reinforced by the top-mount plate.
The leaf spring is intended for the curve to point outwards from the deck, and also presumably increases wheelbase and serves as a riser at the same time.
