Alright guys. This is my first topic ever so go easy on my. I’ve been working with my Enertion Raptor for 3 weeks now and never had an issue until now.
For some reason it wants to brake on its own. It’s actually kinda scary because I will be going forward and it will want to brake all of the sudden in short bursts. Does anyone have any clue as to what’s going on here. Let me know what kinda info you guys need and I will provide it. Thanks ahead of time!
plug it into BLDC tool and check your throttle and deadband. My guess is that your neutral position is closer to the braking threshold so it’s kind of in a “almost braking” position. If that is the problem, you can increase deadband or adjust your min/max pulsewidth to fix it.
@onloop Thanks. I’ll check. One thing I noticed earlier today is that my right hand motor was making a chirp almost like a bird on a 6 mile ride I did earlier. Do you think I might be having a motor issue?
All the connections to everything looks good. BLDC looks good as far as I know. Not only is it braking, it’s jolting forward also at times. Fuck. i love this board. It feels like my kid a deathly ill or something.
Found it!!! One of the remote wires to the vesc came loose. Barely though. I mean it was maybe a mm out of place. Just did another test run and after hitting it with hot glue it works just fine again. Or at least I hope. Going to take it on a long night ride right now to make sure.
P.S- I’m about to go on a long ride tonight. I’ll post here when I’m done.
I took the lid off my GT and hot glued every connection I can find lol. Even plugs such as the motor plugs (they are not three separate plugs, instead they are fitted into one plug) which takes a hell of a lot of force to pull apart, I hot glued.
I’m glad you found the problem, sucks falling off at 20+mph.
Give a try to @Ackmaniac firmware to precisely set the neutral of the remote.
I always have lot of pain setting propreperly the remote with the official VESC firmware.
With Acmaniac one, now, it’s very easy and reliable.
