Right. Basically, a couple of months ago I received a faulty VESC. To summarize, I was never able to make this thing respond to anything - not even light up. My experience with it ended when the capacitors discharged in an explosive manner.
Basically, after balance charging my batteries, I attempted to connect to it (w/ antispark connectors) and everything went wrong.
I followed the manual exactly. Shortly after connecting (2-3 seconds) my 8S Li-Po, the VESC got extremely hot and the capacitors on the VESC exploded and flames/smoke exited through the end of the capacitor. The VESC got covered in some form of liquid (probably from the capacitors) and was very warm. The connector and heat shrink also shows this.
Now I’m looking to see if I can get this thing back in shape. Here is a photo.
I took the old broken capacitors of. I’m not sure if the actual VESC-body in functional. I’m under the impression that the capacitors were incorrectly soldered.
Here is a photo I took while it was in the heatshrink.
Not very experienced with the VESC but I definitely do not recommend testing without any capacitors. Any kind of tiny spike on the input could kill the unit. The caps are there to absorb that. Do you know why the caps exploded? It sounds like either they were mounted backwards, or power was fed in backwards. Both are not a good thing. Did it smoke anywhere else on it, or only the capacitors?
Can you see any burnt traces on the pcb?
If not, check for solder joints on the legs of the chips.,
if everything seem ok, try connecting a regulated 12v lab powersupply.
do you know if it had the firmware and bootloader flashed already?
If not, you may need an stlink programmer and a VM or a PC with linux
If the caps were inverted then its possible that it could be okay. I too am dealing with a lifeless enertion VESC that appears to have no bootloader or firmware. Sigh. I say put some kind of cap on it for safety and then hook it to a lab supply with current limiting so it doesn’t explode again, and see if it lights up. You should apparently get a blue light and then some kind of flashing red light that turns green. I’m not getting the second part of that, only blue, signifying that the power is working but nothing else. If you get neither then there are bigger issues at hand.
I’d love to post my problems but because I just joined, I can’t appear to make a topic yet. Maybe talking with you here will help push me to the ‘tier’ that lets me post topics.
For you, as far as my understanding goes the blue light signifies that the power rail to the microcontroller is alive and well. Then another light means it is scanning for errors, and it blinks red. If it keeps blinking red, you have errors, probably with the mosfet driver chip (it seems finicky from what I’ve been reading and the most likely thing to cause a failure) and if all is well, that red flashing light becomes green and you are good to go. Do you have a bench power supply you can limit to an amp or so to avoid any horrible fires if something is shorted?
Not a bad idea to wait for others input, from my point of view if you don’t see anything obviously burned, you have a lab supply, and can find a small cap to tack on there, I’d go for it and see what happens.
those caps look like they were in the right way to me.
however it is hard to tell from your photos…
there is no problem using a lab supply to boot up VESC and check BLDC tool without caps.
you only really need them when running a motor.
Caps only explode on overvoltage or wrong polarity.
If caps explode but no further sparks / flames on VESC the VESC is most likely still OK. As suggested connect the VESC to either a lab power supply or a 12 isch wall brick and check for LED lighting up. Please try this and reply your findings ^^.
I think the color of the cables were switched, but that obviously doesn’t affect anything. I mainly assumed something was up with the capacitors, since they were the only things affected.
Over-voltage is possible, but I tested with 8s so I think that that is very unlikely.
The color of the wires being switched looks fishy to me.
Did you check that the + coming from the battery connector is soldered to the + terminal on the capacitor board ?
