I have followed every instruction to the letter but these things have never shown any sign of life at all. I read that there’s supposed to be some LED light showing it is getting power, I have never seen as much as a flash. Connecting it to 13 different USB ports, and 4 power supplies hasn’t made a difference. I am at a loss for what to do. They took so long to get here, so much money and now this.
So you said you only get as much as a flash? Can you elaborate on that? If for example you give it a voltage out of the range set in your settings, it will flash red. If everything’s good, you’ll get a steady blue and green light.
Pictures are also useful, as close up and detailed as possible. Sometimes, it’s easy to see a problem on the pcbs and/or components. One of the vesc wizards on here might spot something.
Have you tried connecting to a computer via the usb port?
Hey thx for trying to help.
I actually said I have NOT seen anything at all from the LED’s So I guess I can’t answer that. Furthermore, as My computer isn’t finding it, nor is my brothers, or either of our laptops, there is no range in the settings. I will update with pictures as soon as I get home again.
Every single VESC we are sending out its tested under load by myself. I’m sorry you’re not getting it to work, please send them back and I refund you your payment as long as the are not damaged by a short .
