If you charge with a massive server PSU then your port wont melt and short
I prefer 5,5x2,1 DC Jack ports, but I only charge with 2-4 Amps
If you search for XLR port youāll find it.
I usually buy them in packs of 5 but I canāt find the link now.
Neutrik NC3FPP Nylon 3-Pin F PNL MT āDā Series Blk https://www.amazon.com/dp/B00OVAWM5G/ref=cm_sw_r_cp_api_i_InPfCbG7P2XV1
Like this
And massive
For sure 5,5x2,5 can take 4 amps? That would be enough for me.
I think 4amps āshouldā be ok, my port did not melt yet
BTW, all packages left Germany this Saturday. I hope they get to your homes before Christmas
This makes me super happy because the past weeks have been quite stressful.
@skunk and others who have asked: my father is going order some raw pressed decks. Weāll play with them the same way a car is designed on clay (more or lessā¦). I hope we have something when 2019 starts. [Flat-Kicktail Deck]
the most 5.5mm x 2.1mm dc plugs are rated with 2Aā¦ difficult to sayā¦
mine is rated for 3Aā¦ still not a lot.
Got it? Thanks!
I did a quick check on Mouser, some are even rated at 7A
Yes, I did the same check, but they are much bigger. I just talked about the small M8 style version. If u go for a bigger hole, there are plenty of other good plugsā¦
EDIT: I am wrong there is a 8mm version in 7A, but it looks strangeā¦ I guess its used for mounting on a grounded hole or somethingā¦ so its not very convenient for our purposes. The next one is a 5A Version is not good looking and has a 10 or 12mm core. No information in the data sheet. Do u find a nice one in 5A? @bevilacqua
You are talking about this one? https://pl.mouser.com/ProductDetail/Switchcraft/712A?qs=sGAEpiMZZMv1TUPJeFpwbvDLoO7VplWmGzPCelncVas%3D Itās 5A but 12V in specs. Is it matter that itās 12V?
Hmm good questionā¦ I guess 12v or 42v is not a huge difference for a mechnanical plug.
Yes i mean this plug. Hard to find a nice easy accessible plug like thisā¦
Voltage shouldnt matter if it is only for charging as the produced heat depends much more of the current that the wattage.
If you need a small plug, XT30 is tiny and can handle the current.
Voltage rating is usually for arcing.
Voltage is critical in shortening because of insufficient isolationā¦ heat is no real value for voltage.
Bit the tue difference between 12v and 50 is nearly nothing when we speak about things like plugs or connectors
I created my fist version of the raiser with the XT30ā¦ just exchanged it because @bevilacqua showed me the small dc 5.5mm plugā¦
Maybe I ll upload the XT30 version as wellā¦
This could be good for higher amp chargers, apparently it has a copper needle instead of steel
I use this.
https://www.digikey.com/product-detail/en/switchcraft-inc/S10/SC1950-ND/3909325
https://www.digikey.com/product-detail/en/switchcraft-inc/ST10U/SC2073-ND/4966994
Rated for 11A
xt type plugs are just not convenient. They are not designed for the purpose of quick connecting and disconnecting.
Iām interested in a set of prints for this
