They run good for me… no issues at all. But at the moments its too cold to ride.
Was that printed or CNC’d?
nope not skullboard. @Grozniy these are not the skullboard ones. stormesk8 and someone else is selling them.
That’s actually an insult on this forum
Printed. Rock solid… we ll see how long it lasts… I guess forever. It’s rock solid.
What material did you print it with? Looks good.
ABS… Little overheated, little bit to much material… makes it even stronger.
That’s kickass
Perfect!
Can you throw up the cad files too, for those that want to make adjustments?
Thanks!
Awesome man! You are the real MVP.
I’m gonna try to get an XLR port on my Haya for 7 amp charging… like the rest of my boards
Gauging interest. How many of you would be interested in a SLA print of this?
Not at the moment. What adjustments u need?
Hey can you link which xlr charging port you use please?
Can you specify the switches and led’s you are using?
It’s a quiet basic one!
Backlight LEDs are just basic 3mm red LEDs with round head. 4 in row with an 150Ohm resistor…
Frontlight is not installed yet. But I bought some NSDW570GS-K… they should be great for a basic front light.
He asked Bara
@Indiangummy just google Waterproof XLR, and see if it has enough current rating. There are other multi pin connectors that may support more amperage, but XLRs are usually 3pin connectors
I should go to bed… still have hangover from yesterday
Gotcha, thanks! So the main advantge of those is higher current rating?
